Alarm installation...
I just got an aftermarket Turbo timer installed and was wondering if anybody around here knows how to install a viper alarm so that the turbo timer will be compatible with it. For example, turn the car off the tt takes over, and when I arm the car the damn alarm won't go off, since the car is still running. I heard theres a trick to do this by installing auto start on a car, but i have a manual drive car so no stores wanna do it for me. If you know any other way on how to install an alarm so it will not conflict with an aftermarket turbo timer, let me know please. If you know how to do it the way I just talked bout the autostart installation way let me know. I will hook you up with money and etc whatever you need to get it working! PM asap if you can help me. Thanks!! O yea and by the way, yes i know that viper has a modulator I can put on the turbo timer so i won't have to purchase an aftermarket one, but I Just found that out today! got my tt already installed and ordered if through the net so I aint taking it back. But yea let me know asap if you can help me. thanks!
I <3 BOOST
Re: Alarm installation...
i did it w/my alarm by using an ignition-controlled relay. look on www.the12volt.com for specific info. its all about figguring out which wires you need to connect to the relay to fool the alarm into thinking the car's off.
DESTROYS DONUTS !!
pm Dxplicitone, hes the guru of alarm and electronic gadget installs, and his turn around time is awesome, along with his prices and quality of work.........
