Header Flange Work
Old 07-26-2008, 11:30 AM
OhOneSPI's Avatar
OhOneSPI has disabled reputation
Default Header Flange Work
Hi I got a header made for a Zx5/Zx3 focus and i own an SPI motor from a focus. The problem is they only made a few headers for my motor and i had to resort to purchasing a diff. one. The firing order is the same for my motor so that's all fine. The issue is that i have to redo the flange. Does anyone have any recommendations to where to go or possibly even have air tools?
OhOneSPI is offline
Old 07-26-2008, 12:53 PM
Default Re: Header Flange Work
So you need to cut of the other flange and get the correct one welded on? Do you have the correct one or do you need to get one made?
Old 07-26-2008, 11:26 PM
OhOneSPI's Avatar
I need my current one fabricated to fit. The bolt pattern is wrong, i need 1/4 of an inch taken off the top, and where the new holes across the top are going to be are located in these "bigger" gaps separating the pipes. So what i was thinking was getting a flat piece of steel drilling the new holes through it, making spaces for the pipes and putting the piece of steel in b/w the bolts and the actual flange to keep the header suspended. Cause of the new bolt pattern holes dont have any metal above them, then this will cause the header to either slip or not be securely fastened. Im sorry if i made it sound complicated. It's rather simple, just i have the lack of tools.
OhOneSPI is offline
Chezkers
09-15-2008 05:42 AM
DORKO
09-18-2007 05:37 PM
chirp the 1-2
02-13-2006 02:24 PM
Quick Reply: Header Flange Work
