Local Motherboard Help Needed...
Okay, so I acquired a motherboard... this thing should be a beast, however the guy I got it from failed to tell me he screwed up the bios flash procedure. Usually a big problem, however this is a GigaBit mobo with dual bios. If anyone knows how to fix this, or can fix this for me, I would gladly supply that person with a 6 pack of their favorite beer/ale/lager (assuming they are over 21, soda if under 21). The motherboard is a GigaBit GA-7VAXP Rev 1.1. The GigaBit web page for this board can be found here:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductI D=1595&ProductName=GA-7VAXP%20Ultra
I know someone out there can help me. Thanks in advance.
Doug
757-531-6924
Blaxican-----> this should be right up your alley Tim... help a fellow out, would you?
Doug
757-531-6924
Re: Local Motherboard Help Needed...
the dual bios feature on gigabyte boards isnt actually 2 diff BIOSs, the 2nd is just the original, so you can reload it to the primary without needing a floppy or anything. on post i think it says press F9 or something for dual bios options. just follow the steps and you should be set
if you can't get passed this, I could come by and hook it up, shouldnt take more than an hour regardless.
http://www.gigabyte.com.tw/Products/...-7VAXP%20Ultra
Doug
757-531-6924
Doug
757-531-6924
I'm a big fan of Gigabyte products, so Im pretty familar with all the features, I can come by today whenever if you'd like. Try what I said first, it shouldn't be that hard.
