Machine work needed...
Old 08-11-2012, 06:06 AM
ppayer38's Avatar
ppayer38 has disabled reputation
Default Machine work needed...
Does anybody know of a good shop around here that does machine work? I need to machine out my turbo compressor housig to fit the new compressor wheel...
And also looking to get a divider welded into the Turbine housing....
ppayer38 is offline
Old 08-11-2012, 06:46 AM
Default Re: Machine work needed...
Have you thought about getting the proper compressor housing and a divided turbine housing? You're playing around with some things that are generally design features and not modifications of a different starting design.
Old 08-11-2012, 07:13 AM
VaDriven Mayhem
Lord Humongous's Avatar
Ever thought about using the search button?
Lord Humongous is offline
Old 08-11-2012, 12:14 PM
ppayer38's Avatar
Why spend twice the money on buying a housing when I can get it machined to match?
And there are NJ divided housings for what I'm looking for but no I didnt search cause it is a broad topic being machine work so figured id ask...
ppayer38 is offline
Old 08-11-2012, 01:38 PM
Depends on the results you want. Do you want good results, or do you want results that cost a fraction of the cost?
And you're talking about welding a divider into a cast iron turbine housing. If you don't know why that's not going to work very well, you should keep doing research.
Old 08-11-2012, 01:59 PM
ppayer38's Avatar
Well the divider isn't a must but id like to have to have it done... Putting a new wheel into a housing isn't a huge deal as long as it is machined properly. Just cause something is cheaper doesn't mean its inferior.
The divder I have seen done before with good results and I know its a pain but cast iron can be welded and made. Plenty have welded flanges on manifold, etc so no lecture needed here.
ppayer38 is offline
Old 08-11-2012, 02:16 PM
Originally Posted by ppayer38
The divider I have seen done before with good results and I know its a pain but cast iron can be welded and made. Plenty have welded flanges on manifold, etc so no lecture needed here.
The turbine housing is designed around whether it is a divided scroll or not. Welding a divider doesn't make it into a proper divided scroll, it just makes it a single scroll with a divider added. Not the same.
I'm pretty much done arguing this though, rig up whatever you feel like to put on your car.
Old 08-11-2012, 02:31 PM
VaDriven Mayhem
Science motherfuckers
Old 08-11-2012, 05:41 PM
ppayer38's Avatar
I wasn't making it into a twin scroll turbine housing... I wanted to make a divider that goes inbetween the turbine wheel and wastegate flapper so I can run am EWG off the housing/DP instead of having to patch it into the uppipe and run all that piping to reroute it back into the exhaust...
Sorry if it was a little misunderstood to what I wanted to accomplish. Now I see why you though it was not gunna work haha
ppayer38 is offline
Old 08-11-2012, 07:43 PM
Ah, gotcha. You could also weld the wastegate divider into the downpipe (protruding into the turbine housing past the downpipe flange) if that's an easier solution.
Quick Reply: Machine work needed...
