My Engine Is Blown!
#61
Re: My Engine Is Blown!
Originally Posted by six out 6
Mine winds up full at about 3-3.5k rpm. Then the cam falls out around 5k or so. Modified to a external w.g., and a crappy MBC. A H22 isn't a prefered motor to F.I., it's just the valves.. they aren't all that strong for turbo/s.c. Honda motors are built for all motor from the factory, so some things are expected to be upgraded. The H23 on the other hand is a great subject to F.I. Iron block, AWS (Si), and just a relatively strong motor all around.. but I still won't own another Honda.
#62
Dont Be Scared Homie
well, i don't know how TD05's react in other applications. in me and Six's cars, on a stock cam, the power drops off around 5.3k-5.5k. we don't have alot of top end, but shitload of torque. so more or less, the turbo is somewhat inadequate for our car. it's a low stroke 2.6L with a 7.0:1 compression. i mean, there are cams for our cars which allow the engine to make power in the 6.5k-7k range, so i guess it balances out. the thing with the JRSC, they ARE adjustable. if they make pulleys with a higher psi, then you can just bump it up. i'd ask around and see what some people say, like what kinda experiences they've had with their setups and go from there.
#63
