Need check engine code read in NN/york
My beater (1990 accord) has an engine light on. The only problem is autozone can only scan from 95 or newer, im never taking it to the stealership to pay 80 bucks again for the code read. Anyone know of a place that can pull the codes for free? Also the engine light wont come on unless im on the interstate doing about 65. Anyone have any ideas of what it could be?
just a little 4x4
Re: Need check engine code read in NN/york
dunno anyone that does em for free . .. . guy on jefferson that runs smith's auto (just south of brierfeild) does em for like 45 I think . . . and most advance auto's have all the adapters to do it but the people working there are told only 96 and up cuz they are easier and you dont' actually have to think much to do em . . lol
やくざに成りたい
you do realize for your accord all you have to do is short the connector behind the passenger kick panel with a little piece of wire, then turn on the ignition and count the number of times the check engine light flashes, then when you get how many times it flashes, just check the code and see what it is (they have a chart on honda-tech if you search there) but if it only comes on on the highway and then cuts off i dunno, try resseting your ecu and then see if it happens any more. (pull the ECU fuse under the hood for like 1 minute) hope this helps
Cpt. Non-Spell
10-04-2006 03:47 AM
