Place to buy Kaaz transmission fluid?
braap braap
Re: Place to buy Kaaz transmission fluid?
If thats true, then I'll be heading there tomorrow morning.
OR. If I can't find it locally, anyone have a good enough replacement?
I've been told GM Syncromesh is ok. I just don't want my clutch type LSD to be going crazy like it is.... and I want to go get tuned.
braap braap
Friendly Jackboot
for whats it worth the kaaz stuff (yes i have a kaaz 2way in the drift car) and after every event i change it with torco or lucas oil...any NON synthetic 75or80w90 will work fine, to be safe i also use a bottle of torco lsd additive (ford type). the kaaz stuff is WAY over priced and the exact same as the other stuff. you're paying for the name...nothing else.
EDIT: I just realized this is for a tranny, not a diff...however i'm sure the above still applies.
braap braap
I bought 2 quarts of GM Syncromesh and left a haft quart of 80w in there. My problem is starting to go away. I need to go do figure 8's and it'll stop poppin. I can't do but so much hard driving with others on the road. It drives fine untill I lock the wheel one way and go.
Thanks again for the help ya'll. This thread is done.
Friendly Jackboot
It does.
