RB questions
Re: RB questions
The reason i have it here is to find someone in this area without a shop. I have taken it to 3 shops now with no results. I am asking for someone that does it on the side. thanks
Re: RB questions
What is your specific problem? Which rb? You should reply to these question via pm as your thread will get locked/ moved soon and I don't usually check tech talk.
Edit: I saw your other post that got moved. You need to check your TPS to make sure you are getting the approprate signal to the ECU. The stalling is more than likely because of being lean, you should not own this engine without a wideband. Acquire one. You should also specify within your PM any additional mods like Q45 thottle body, freddy manifold, bigger injectors, 300ZX MAF, etc.
