Rebuilding a turbo
![1slowpony is a name known to all](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![1slowpony is a name known to all](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I want to take my t25 turbo and get it rebuilt because it is leaking oil into the exhaust. I was wondering what shop I could take it to and how much?
Thanks
Thanks
'08 135i & '00 S4
![audiS4_apr is on a distinguished road](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
How bad is it? There's a point where a groove gets worn into the surface of the shaft hole (at the turbine end) and it can't be rebuilt. It would be like having a groove in your cylinder and expecting piston rings to seal at that point. In that case you need a new center section. I think you should check with blouch turbo. I mailed my K04's to them for bigger compressor wheels.
http://www.blouchturbo.com/upgrades/
![Dick has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
there not the best at rebuilding any turbo's i used to do a lot of business with them and if it lasted a month i was lucky.I lost a lot of money and business useing them
