relocating rear fender tabs
Re: relocating rear fender tabs
I'm having to cut and paste this a lot recently:
Forum: Tech Talk
Anything technically related to your vehicle should be posted here. If you're looking to have work done, try one of the Regional Forums.
I'm moving this to 757 because your FS threads say you're in VaBeach.
Forum: Tech Talk
search s2ki, its easy to do, just cut and remove you stock fender tab and drill a new hole about inch back, and install a self taping screw.
Self tapping screws are never a good solution for anything. Especially a car you actually care about.
Oh, I forgot. They're a good solution for air conditioning ducts in your house.
I cut and sanded mine with a dremel, sprayed it with some anti-rust. Drilled a hole further back. Used a stainless bolt and nut.
PM if you need more help.
appleseed
06-09-2010 10:32 AM
