Someone in 757 able to help me figure out what's wrong with my car?
Re: Someone in 757 able to help me figure out what's wrong with my car?
could either be
-cv joint
-loose lugnuts
-low tire pressure
-wheel balance
but i dont know what type of knock it is i need to hear it!
-cv joint
-loose lugnuts
-low tire pressure
-wheel balance
Thanks, I know this should be in tech, but I'm looking for someone to ride with me for like 5 minutes to hear it. If it is the CV joint I'm screwed because I'm broke.
How come the CV Joint kits I see are like upwards of 150, but I can get a whole axle assembly for like 100? I've seen a few posts where you talk about getting parts, where do you work?
Bap Geon in Norfolk
The best way to replace them is the whole axle. Its more time and cost effective. Like I said I usually sell new ones for $60 and remans. for about $50.
Why does this cost so much?
http://oem.overnightautoparts.com/pa...20Kit&dp=false
I'm going out of my mind trying to find out what it is.
http://oem.overnightautoparts.com/pa...gory=K&dp=true
What you need is the whole axle.
