accord suspension problem
Old 04-16-2003, 06:05 PM
i have an mr2 now
Pimp96Accord's Avatar
Pimp96Accord is an unknown quantity at this point
Default accord suspension problem
can anyone help me with my accord, the left side of my car is lower than my right, if you had this problem before let me know how to fix it or if you know a way to fix it please write thank you
Pimp96Accord is offline
Old 04-16-2003, 06:25 PM
sup
SCOOBY STEVE's Avatar
SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE
stock suspension? coilovers? springs? adjustable struts? stock struts?
stock suspension: replace it, fuck it!
coil overs: make sure both sides are adjusted properly, or maybe you need new struts
springs: got new struts?
adjustable struts: adjusted properly?
stock struts: get rid of them fuckers!
just my .02
steve-o
SCOOBY STEVE is offline
Old 04-16-2003, 07:14 PM
s2k7's Avatar
s2k7 has disabled reputation
Accords are famous for one side being lower than the other. There isnt a thing you do about if you have springs. If you have coilovers just raise the left side up a bit....
I had the same problem with my right front though. I just adjusted the difference.
s2k7 is offline
Old 04-17-2003, 10:45 AM
i have an mr2 now
i got stock struts, and goldline lowering springs that lower 2.25
Old 04-17-2003, 01:14 PM
s2k7's Avatar
Struts wont do you a thing. All i can say...( which is a shitty solution) is put those spacers in between a coil or two.( if they even will fit in there)
s2k7 is offline
Old 04-17-2003, 07:57 PM
Old guy
kutza's Avatar
kutza is an unknown quantity at this point
when the springs were installed, was the weight of the car put on the springs and ride height correct before the front lower strut bolt was tightened? If not there maybe a preload on the bushing causing it to not fully colapse to the ride height.
kutza is offline
Old 04-18-2003, 04:04 AM
s2k7's Avatar
That wont help you....being there is no adjustment just a hole for the bolt to slide through. Applying load on that in nessesary. And the other bolt that tightens the fork to the strut will only go but so far down and you go push that down with your hands.THe only time i know of that a load needs to be applyed to anything is the upper control arm when installing a camber kit.
s2k7 is offline
Old 04-18-2003, 04:48 AM
Atheist.
Skywalker's Avatar
Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker
This can happen over time, if the car is used to having only the driver in the car and no passenger (hence the reason why the LEFT side is lower). Replacing the shocks/struts should help; start with the front.
Skywalker is offline
Old 04-18-2003, 07:32 AM
s2k7's Avatar
Sure didnt help on my car....and i have koni yellows
s2k7 is offline
Old 04-18-2003, 07:49 AM
Atheist.
Skywalker's Avatar
So you had the same problem, tried replacing the shocks, and no change?
Hmmmm, Accords must be POS.
J/P
Quick Reply: accord suspension problem
