Anyone with K-Pro Experience
![seventytimes7](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![seventytimes7](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Just got k-pro and have run into some complications. tried to load stock map but immobilizer was blinking. tried to start but cranked and cranked no luck. turned immobilizer off and tried to start again still same thing. called hondata and they tell me to pull plugs and fuel rail. that cant be it because my car was running flawlessly right before i sent my ecu. if anyone has any clues it would be appreciated.
So you sent the ECU to Hondata to get the K-Pro installed?
If the installation was done wrong, the immo would disable the fuel pump, etc. This is why they are having you check the rail, etc. They may have sent you back someone else's ECU, in which case the immo would freak out, and I'm not sure if that's stored in the ECU or not, so I'm not sure if disabling the immo after that would help or not. I don't know much about K-Pro setups, I'm just giving general OBD2b advice.
Also it's a real long shot, and really not very probable, but:
Check all the connections where the ECU harness plugs in to the ECU, I've occasionally seen a pin back out of it's connector shell if the ECU has been unplugged and plugged back in. Like I said, very unlikely but it has happened.
turning immo off in kpro takes care of that iss... Kpro is a fully programmable ECU unlike the old b series... They are giving you basic trouble shooting in my opinion... have you installed your base calibration to your car? you may want to try and follow the steps again to make sure it is in properly.
what car is the K motor in????
ya ill check out the prongs today after work. the k-pro is in an 03 si, someone said on the base calibration i have to load the calibration with the immo off two times in a row for the ecu to accept it. ill try that also. thanks guys
not sure how the SI runs but you are backing the key out of the on position after you load the calibration right? Id take it completely out of the ignition which worked when mine did the same thing...i have an RSX though.
Vtec kid
Engine / Exhaust / Drivetrain
14
02-08-2009 04:45 AM
MorrisMtrsports
04-08-2007 02:36 PM
