BUILT MOTOR? Discussion. READ
#151
sorry to be brutally honest, but you are pretty illiterate. You should probably take a 9th grade english class again.
on a side note, not saying rep even matters, but seeing that i have more than both of yall, i obviously have adding to conversations a little more than you.
#152
#153
#154
wadafuxup
![burton has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![burton has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
#155
Boost is Better
![sircrx](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![sircrx](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Dude you were in one of the threads bitching about a built motor that I was looking at. While THAT one may not have been a "built motor" by any means your description was well over what could be described as "built".
Like I stated in that thread that you came in and bashed up was this
Yes people do use the term too loosely sometimes but there is always a different definition between different people.
I've used the term "FULLY built" before but then reiterated that it wasn't sleeved.
SO... in your terms what should I call that?
If I have
cams
springs
retainers
port
polish
Pistons
rings
rods (H beam) or rather fuck it even if I had aftermarket I beams
bearings
STOCK crank but knife edged and balanced rotating assy to 10,000rpm
cam gears
fuel rail
and ill stop there because to ME
thats built cuz it damn sure aint stock??
May not be fully built at this point but it is built.
My teal hatch I just sold was a "built" motor and put down 415hp and 270ft lb of tourge at 15.55psi TO THE WHEELS and you don't want me to call that built? what is it then.
If I have
cams
springs
retainers
port
polish
Pistons
rings
bearings
cam gears
fuel rail
