HELP, need advice
Old 05-07-2005, 11:51 AM
dreamer1997's Avatar
dreamer1997 is an unknown quantity at this point
Exclamation HELP, need advice
Ok guys I dont usually post on here btu i am in serious need of some help.
I need to get my car inspected down here so i can register it in Virginia, there is only one thing I'm pretty sure that I wont pass inspection. My front blinker covers are cracked and mostly missing. My drivers side window doesnt go up and down on its own.
Ok so i need advice, where is the best place to get new to me covers for the blinkers? a pick and pull, or a dealership or someplace else. Is the window going ot make a huge difference?
IS there anything else i need to worry about?
I would appriciate any and all help and advice anyone has to offer. THANKS!!
~Jennifer
BTW I have a 97 Mercury Cougar and live in the Tidewater area
dreamer1997 is offline
Old 05-07-2005, 12:23 PM
HHIC
Flite's Avatar
Default Re: HELP, need advice
Just go buy a damn turn signal cover. The window shouldn't matter.
Flite is offline
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
The inspector has to be able to roll the driver's side window up and down in order for it to pass inspection.
Grease Monkey is offline
Old 05-07-2005, 12:26 PM
ok but where? and are they hard to install? i need one for the right and the left...
Old 05-07-2005, 12:28 PM
ok but what if the window is already down would they check then? wishful thinking i know
its the motor or the teeth on the gears, no one has ever told me which is the reason the window doesnt work
Old 05-08-2005, 02:48 PM
Unconfirmed User
BlewMR2's Avatar
BlewMR2 BlewMR2 BlewMR2 BlewMR2 BlewMR2 BlewMR2 BlewMR2 BlewMR2
just make friends who are able to do inspections.. that way you can get the sticker for free (yes, it works.)
BlewMR2 is offline
Old 05-08-2005, 03:47 PM
master debater
blackout's Avatar
blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout
most inspectors are looking to 'upsell' when they inspect- which means you can pretty much count on them checking everything. some even go the extra step and know what to look for on certain types of vehicles (hint- don't take it to a dealership unless you're trying to find out EVERYTHING that may be wrong with your car, inspection-related or not). so more than likely the window will be checked if it's the driver's window.
more than likely the window regulator is what's broken, and they are a pain in the ass on nearly any car. if i remember correctly they aren't too bad on the cougars though (i used to work as a tech in a lincoln-mercury dealership). you're looking at $100-150 for the part plus about 1.5 hours labor, which depending where you go, the rates for labor range from 35-80 dollars.
good luck, cars are expensive. btw a word to the wise, get out of that cougar any way you can, they are horrible cars to maintain. especially if it's a v6.
blackout is offline
93DOHC
01-24-2008 02:00 PM
VanillaThrilla
03-18-2005 04:55 AM
Fraud
05-03-2004 05:56 AM
Quick Reply: HELP, need advice
