NOS, Nitrous Express, Zex, or Nitrous Works?
I was wondering which nitrous setup is the best. NOS, Nitrous Express, Zex, or Nitrous Works? And please, if you know nothing about nitrous, don't act like you do. Thanx!
i have a nos system that works really good for me and my friend had a zex system that was shitty if that helps you out but if your really tryin to go all out and have a nos car like me there is this system that i am saving up for its the nitrous express direct port it comes with the fuel rail and everything it is really sick but it cost like 1000 and i think its only out for hondas now but hope i could help
It has 4 Doors...
well I don;t have NOS or anything but jsut my $.02 would be to spend you $$ on the NOS kit as that's the true name that has been tested time and time again and is known to perform and meet the needs of the NOS heads that have to have it.
So if you are going to spend the $ I say get the Original NOS...
Good luck w/ your purchase and decision...
i have a zex kit and i love it... i installed it myself in like 2 hrs.. very nice, easy and worth the money.. now if you are concerned about saftey all the kits are safe..
1) zex uses bottle pressure to reference and adjust how much the fuel pressure regulator is bumped up.
2)venom is all computer controlled(all aspects)but very pricey
3)now i am not fimialliar with nx and NOS, but they are all just as safe as the others.
4)the question is how is your car? if it is not in perfect working condition, dont spray. this is where problems complicate themselves and cause major damage.
otherwise it is pretty much what brand you want.. all are realitively safe and peform the same.
5) do you want a wet or dry set up? wet mixes fuel with n20 at the nozel to reach a good air/fuel ratio, dry bumps fuel pressure to attain the good air/fuel ratio...
but i say zex b/c thats what i have and what i am familliar with..
and good luck with everything
Originally posted by LSPinoy
how safe is it to use a nitrous system on an automatic transmission? if you can only spray at open throttle, what gear or rpm level would you engage the nitrous?
