Need help w/flat tire.
Re: Need help w/flat tire.
man if you were closer id mount the tires for you. i dont know what size you need but i have some pilot powers for sale in the forsale section.
plugging the tire is a NO NO. which would you rather pay for, a $150 tire, or putting yourself and your bike back together?
ive always said to people using take-offs at the track "is a $250-$300 set of tires worth your $9,000 bike?"
Wow someone else with some sense!!!!!!!!!! Sorry fellas but I agree. Give us a call at EMC We do charge 40 dollars to mount but our tires are 125-135 depending on size. We might give ya a break if you tell us u saw it here. And Gazoo I wouldn't be putting Skr00zs name out there like that!
thanks for all the concern, and yea its a 130/90-17 (well thats what I have on, not sure what other sizes fit).
Anyways, I pluged it today (like OMG!) and so far so good. But I only rode like 5 miles. I'll keep an eye on it, I might replace it during the winter. I can grab a new tire off ebay for like $100 give or take. Hopefully the plug thing will work out.
ive plugged 2 motorcycle tires before ( i work at a vb gas station) and ive never had anyone come back and complain, and a properly plugged tire should last the life of the tire
you arent supposed to plug a motorcycle tire. i really think you should reconsider what that $100 tire is worth to you.
when your tire is punctured, it creates a tear in not only the exterior of the tire, but the interior structure of the tire. on a motorcycle tire, its being pulled/scretched around as you lean through turns, and its only going to pull/stretch around that tear, eventually causing it to leak, hopefully not blowing out all together. ask any motorcycle shop to plug a tire for you and they will say no, as you have found. theres a reason for that. its not safe.
i hope you rethink replacing that tire. if not, be careful out there man...
on a side note, i was mounting a pilot power 2ct for my buddy last summer. i accidentally punctured the tire mounting it. he was ok with patching the tire. i told him definitely not and i went and bought him another tire on my dime. im not holding that shit over my head when something goes wrong..
As far as tire sizes for the EX500, I would recommend a 140/70 radial. Right now, I have a 150/60 on the rear, and due to pinching, there is unusable tread and no matter the lean angle, I can't touch it.
Unless you change your own tires, it's sometimes cheaper to buy and install a tire at the same place.
Have fun, be safe, and keep the rubber side down.
Kellie
