Tires???
Old 07-30-2006 | 01:39 AM
The_rabbit1's Avatar
Fidel runs VBPD
The_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud of
Default Re: Tires???
turning is different when changing tires. wider tires lean a bit slower.
Old 07-30-2006 | 01:54 AM
Armenian's Avatar
CLUTCH IT UP
Armenian has disabled reputation
pilot powers are cool just dont do wheelies on them in the first 5 miles like my dumbass did and end up jumping off the bike.
Old 07-30-2006 | 08:28 AM
skr00zloose's Avatar
hatrs make me famous
it's not the width, it's the profile that makes it turn "slower". a 180 on a 5.5 rim has a more pointy profile than a 190 on the same rim.
Old 08-01-2006 | 12:59 AM
Fidel runs VBPD
this is true. but going from a 155 to a 170 my bike turns slower. leans farther but gets there slower.
Old 08-01-2006 | 06:59 AM
uh, what the hell are you riding that has a "155" on it??
and the reason it turns slower going up that far on tire width is probably because if the rear was a "155" (which i've never heard of) and you went to a 170, then you put a tire on a rim that it wasn't designed for. going too wide can kill handling if you don't run a rim that's the proper width too.
Old 08-01-2006 | 08:42 AM
Voodoo ST's Avatar
Handling is Key!
Voodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these parts
With the 180/55 you will be able to make transitions quicker..... Thats what I race on.
Old 08-01-2006 | 03:17 PM
lildogg's Avatar
Lil Tree Big Branch
lildogg has disabled reputation
Well fellas as of right now I am not even worried because I have decided to sell the bike.... I am going to put the 180 on it and let her go!!!! Need to money to make more money.....
Old 08-02-2006 | 11:19 AM
Fidel runs VBPD
94 katana, and i switched the wheel to a 98 katana to go with said tire. fits great.
Old 08-02-2006 | 12:48 PM
a 98 katana rear wheel is only 4.5" wide, and comes with a 160 on it. i've never heard of a 155.
also, i know the 170 fits, but it "squares off" the tire, and makes handling a lil worse. but if you're not out cranking double digit exit ramps, you probably wouldn't notice much.
Old 08-02-2006 | 01:48 PM
k20-s's Avatar
k20-s has disabled reputation
i can get you a BRAND NEW tire at (frederickburg motor sports) for 20% off.
jdmontheway
Want to Buy / Trade ARCHIVE
05-27-2008 07:37 AM
Quick Reply: Tires???
