13.1 eagle strocker b20b long block
Build..Race..Win..
![vtecda9 is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![vtecda9 is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
i think people are looking to buy, you said you had another motor you are building, why not just put a price an sell straight out,
glwt
glwt
Description: i have a fully built stroked b20b block the stroker kit is all eagle as seen in pictures and the piston are ares with brand new ares file fit rings for nitrouse h beam rods made by eagle the block had new type are water pump new oil pump new king racing bearing arp head studs it has arp rod bolts stock main bolts arp flywheel bolts les then 200 miles on motor due to pulling out cause i wanted to finish my fully built boosted setup the motor ran goos loads of power
spooling -gsr-ej1
![1sloEF](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
