b20 p8r head, crower, big hp
way of contact: here or 804 436 2531
all parts are used but are in great condition with 3000 miles on them unless otherwise stated.
b20 P8R head...if u dont no what it is reseach is your friend... the head is FRESH it has 3000 miles on it. when i got the head it was reallyyyy clean BUT i took it to the machine shop and had it checked out. the head was completely dissassembled, cleaned, new valve seals, crower dual valve springs, titanium retainers. i have receipts for the machine work and the valve springs, i might b able to find the one for me buying the head. the head is complete from top to bottom with no dist. or IM. comes with valve cover cut for cam gears. comes with stock cams. - $600 - pics show a bare head BUT comes as it looks but with, stock cams, original cam caps, all bolts, fresh vc gasket, cut VC, bolts for dist, cam plug, cam seals, cam gears, everything realy except dist and IM.... - $600
crower 62403-2 cams... stage 2 ls cams... 3000 miles on them...with skunk 2 blue adjustable cam gears. - $300
obd1 LS intake mainfold... mani been bored 4mm. over where the TB bolt up. - $75
odb1 LS Throtle body... bored 4 mm. over by maxx bore every now and then the TPS acts funny. - $100
obd1 LS Distributor... converted to external coil. comes with accel 300+ ignition system, coil, ignition box, wire that goes from coil to dist. $250
all parts OBO. can package together if u want all parts. will trade for b20 vtak parts. need... obd1 b16 IM, obd1 TB, obd1 vtak Dist. b20 vtak head studs.
sorry for the krappy pics....camra fone... will get new ones once the battery charges to my camera
Re: b20 p8r head, crower, big hp
alright i need cash for another build will sell complete head, crower cams, and skunk 2 cam gears for $800
