Fully build ls-vtec for boost
Means of contact: 2406037149
Price: $3500
Description: Block: ls b18b 0 miles on block
81mm
Golden eagle sleeves
O ring
Cp pistons 9:5.1
Eagle rods
Ls crank
New oem water pump
New oem oil pump
Oem head gasket
Oem tensioner
Oem timing belt
T1 block fittings
Moroso 5.5 oil pan
Oem alternator
Arp exhaust studs
Arp head studs
Head: 2001 Gsr
Port and polish
Supertech valves
Supertech springs
Supertech retainers
Brian crower stage 3 cams
New valve seals
New cam seals
New keepers
Toda racing cam gears
Oem distributor
Ngk spark plug cables
Pictures:
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Price: $3500
81mm
O ring
Cp pistons 9:5.1
Eagle rods
Ls crank
New oem water pump
New oem oil pump
Oem head gasket
Oem tensioner
Oem timing belt
T1 block fittings
Moroso 5.5 oil pan
Oem alternator
Arp exhaust studs
Arp head studs
Head: 2001 Gsr
Port and polish
Supertech valves
Supertech springs
Supertech retainers
New valve seals
New cam seals
New keepers
Oem distributor
Pictures:
gsrsuperman
12-28-2010 06:21 AM
