Brake Rotor install shop reccomendation
Old 02-15-2007, 02:46 PM
Overrhypedlude's Avatar
Overrhypedlude is an unknown quantity at this point
Default Brake Rotor install shop reccomendation
I was quoted $270 for installation of new aftermarket rotors which I think is a bit excessive.
Anyone that had rotors replaced reccomend a reasonably priced shop around the Northern VA area?
Overrhypedlude is offline
Old 02-15-2007, 02:51 PM
Needs a fast car now
NX2KDET's Avatar
NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET
Default Re: Brake Rotor install shop reccomendation
Total Auto Repair & Motorsports off Rt 1 in Dumfries
NX2KDET is offline
Old 02-15-2007, 03:08 PM
i <3 haters..xoxo
frk_concepts's Avatar
frk_concepts has disabled reputation
Hybrid Garage
71 Capital Ave suite 101
fredericksburg,va 22406
540.368.0030
www.hybrid-garage.org
frk_concepts is offline
Old 02-15-2007, 03:54 PM
98coupe's Avatar
98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts98coupe is infamous around these parts
Why not do it yourself, it is pretty easy to do.
98coupe is offline
Old 02-15-2007, 03:59 PM
Say somm!!!
NastyNate's Avatar
NastyNate is an unknown quantity at this point
I can do it this weekend...shoot me a PM, it will be alot cheaper.
NastyNate is offline
Old 02-15-2007, 04:14 PM
<3
RotaryX7's Avatar
RotaryX7 RotaryX7 RotaryX7 RotaryX7
Its just 2 bolts on the outside of the caliper (depending on Caliper (could be up to 4). Then the Rotor comes right out, and Put the new one in, and then put the 2-4 bolts back in. Then Waaaalaaa, your done! Just keep the brake line in so you don't have to bleed it. Shouldn't take any more then 45 min's, maybe an hour if you have no Idea what your doing.
RotaryX7 is offline
Old 02-15-2007, 04:38 PM
I am SLOW SON !!
Slepping_H22_DC's Avatar
Slepping_H22_DC has disabled reputation
I charge people 40 bucks with new pads also. I have a lift and use air and correct rotor punch tools and clean the calipers. That price is just stupid.
I will be at the shop tomorrow wrenching me jeep if you want.
Slepping_H22_DC is offline
Old 02-15-2007, 06:54 PM
Great..thanks for the offer.
The body shop price quote pissed me off. Must be that so called "vette tax"
Once the car is out the body shop I'll shoot you a PM and stop by on a weekend.
Can you adjust the air gun to the exact TQ specs? 100 lbs on the lugs and 125 on the caliber brackets
Old 02-15-2007, 07:28 PM
Needs more poke.
Tarzan Bakerada's Avatar
pssshhhhh who needs torque specs? I use the good-n-tight method. Never failed.
Tarzan Bakerada is offline
Old 02-15-2007, 07:35 PM
JAY SPEC
00civichatch's Avatar
00civichatch 00civichatch
if it dont break its tight enough!
00civichatch is offline
Quick Reply: Brake Rotor install shop reccomendation
