Electrical Guru's [ need help]
Just bought a 94 civic coupe for a DD, and it needs some electrical help.
my gauge cluster doesnt work, and when i turn my headlights on, my corners dont work or stay on and also my taillights doesn't stay on, only when you brake...
anybody can solve this problem, previous owner says its not the fuses,
MONEY TALKS
MONEY TALKS
Re: Electrical Guru's [ need help]
I had a 1990 DA that had this problem, or at least a problem along the same lines.
One evening I was driving it, and all the console lights went out, even though the headights were on, and the brake lights didn't work either.
What it ended up being was that water had seeped into the tailight buckets and had shorted out the wiring there. Dried it up, replaced the fuse, and we were all good to go.
I know the previous owner told you that there wasn't a fuse problem, but I would go ahead and check them all anyways. Couldn't hurt.
Good luck!
Good luck!
Good luck!
Good luck!
