**Turbo Car Hits Boost Cut**(Need prevention)
#21
RVA is for Hustlers
![JDM_EF-9 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
Hahah actually Im open downpipe with no 02 could that be it?????
#24
RVA is for Hustlers
Ok ima check. I usually give it between 50-maybe 75% throttle not really WOT because I catch no traction between 80-100% throttle. Its happens sometimes not all the times. When you say spike, that means it doesn't go over 19psi correct? Thanks for all the help and support.
#25
No, i wouldn't think it would be a problem as long as it was tuned that way.
How long have you been running on the stock clutch?
Spiking is a term that means somethign of the lines that....even though your boost is set at 7lbs....you have something that causes it to peg another higher psi level.
#26
RVA is for Hustlers
Umm since July 08'. Not too long but total of maybe 85% clutch left. I shift at like 3K 99% of the time. Only hit boost a total of 5-10 times.
#27
Slammedxpert
![SortaFlush](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![SortaFlush](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I.e: 7lb spring...but the car is spooling to 7+ lbs of boost, not just 7, because there is a problem somewhere in your setup.
#28
RVA is for Hustlers
my limit is 8 pounds so when it try to creep over 8 it likes cuts to protect from over boost do you know what im talking about?
#29
I think you problems are in your injectors. stock injectors on 7 lbs. is not enough they are prob. at 100%... try running a higher set and retune, have a feeling that the next time or two when she runs in to fuel cut you'll have a cracked piston or two .
#30
Slammedxpert
What manifold do you have? What wastegate? and check your vacuum lines and routing.
