01 gsr problem...need help
Re: 01 gsr problem...need help
Yea if you change the coil in the distributor then it should fix it.. The guts of the distributor usually never go bad,just the coil.. Changing the rotor and cap would help for better spark also..
Can't check if coil is bad. Plugs smell heavly of fuel. Checked if I had spark. I have no spark on any plugs. I have ngk wires. No damage to them. Took cap off. Where the rotor connects to the cap to make spark those metal things are white n 2 of them look like a little burnt. The rotor is white n looks burnt. Top of rotor where it connects is dark like its burnt I should say n bas is all white. So im guessing cap n rotor need changed n plugs. Any thoughts that coil or dizzy is bad? Idk if it means anything but the rotor spins freely also when u crank the key
Mine just doesn't start lol. I took ignition coil out n the rotor. Rotor looks burnt so since I work at pepboys ima buy my parts cheap lol ima change plugs cap rotor n ign coil in hopes cause I have no spark period
Previously Odyssey
I hope you unplugged the distributor before cranking it up with the cap off. Otherwise, if the coil was good, it is quite possibly fucked now.
And why can you not check the resistance of the coil?
It is super easy and takes like 30 seconds with a DMM.
Edit:
http://www.team-integra.net/forum/bl...eshooting.html
Can't check since I dont have the tool. N yes dizzy was unplugged. Rotor n cap look burnt up. Look kinda white n where the rotor touches the cap it looks pretty burnt
