1987 Volvo 780 idle problems??????
#31
Re: 1987 Volvo 780 idle problems??????
So if your not getting any fuel, check the fuel pump and the fuses for the fuel pump. Sounds like the fuel pump probably slowly crapped out
#32
Bow Down
Yeah I did some research and The car has two fuel pumps. One inline and one intank. Prior to the idle issues I heard this bad whining noise underneath me. And the night before last it had stopped when i pulled in the driveway. That next morning it wouldnt start. So I am assuming that the one inline crapped out on me. Im going to replace it and see what happens. Thanks for everybodys help.
#33
If you need to take it somewhere, take it to rwturbo, great standup guy, VOlvo specialist, and he'll be cheaper than A Volvostore, although Volvostore does excellent work also.
Inline pump is likely.
#35
Bow Down
Originally Posted by geonfreaq
If you could hear it pretty good it was most likely the in tank one. Call Tom up man they are pretty cheap.
So if the inline pump dies, the car wont run at all?? Could the intank still be good??
Hey geonfreaq, can i get part numbers and prices for both pumps??? thanks
#36
Originally Posted by ECR
I heard the whining noise through the center console area. Thats where the inline pump is.
#37
Bow Down
Ok i didnt know where you were hearing the noise. Ill check the prices tomorrow for you. Im on my phone right now...lol. For the cost of the pumps you better replacing them both.
Thanks I appreciate that. I am replacing both. I figured the inline pump went bad becuase of the intank pump being bad also. Thanks again.
#38
Pre-"Crash" Member
Most likely your inline pump. Replace that first before you go through the hassle of replacing the intank one. It's possible for one of these cars to run with only the inline pump working.
#39
Bow Down
Originally Posted by growley
Most likely your inline pump. Replace that first before you go through the hassle of replacing the intank one. I've actually seen one of the cars run with only the inline pump working.
RCR Roscoe
Engine / Exhaust / Drivetrain
12-27-2009 10:57 PM
