1991 CRX not starting
![cardana24](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![cardana24](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Hey guys, I have a 91 CRX HF. It is stock and has the d15 engine 5 speed transmission. Before this morning I had not had problems with it. I started the car this morning, and it ran for maybe two seconds then cut off, and would not re start. I sprayed some starting fluid in the throttle body and that did not change any thing, it would just turn over and not catch. So I tested for spark with my inline spark tester. I was getting spark and it was orange in color...so I assumed I could have a weak spark because of a worn coil, so I replaced the coil....and nothing changed. I have not done a compression test, but I really doubt I lost compression over night. Also, I removed the oil filler cap to to see valve spring/cam, and cranked the car and verified that things were moving, everything seemed fine so I don't think the timing belt broke. I checked my ecu for codes and the only code I am getting is "1", which from looking online I think that is a oxygen sensor code. What am I missing? Why would it not attempt to start if I am getting spark and a spray starting fluid down the throttle body? Thanks for any help.
i pooped a squirrel
![Gen_Crunchytoes](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Gen_Crunchytoes](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
first. thank you for actual posting a proper thread. really, thank you
did play with the timing at all? id pull the plugs and check them as well just to rule that out entirely
I think you need to look into replacing the entire distributor. I have seen tons of D series give those same symptoms and the distributor be to blame. It is obvious that it is spark related from what you are describing, so swap in a new distributor, cap, and rotor.
Am I correct to assume that an orange spark is not great? I think I am supposed to get a blue spark from an engine that runs well. The only thing I checked with the distributor is that it turns when the car is cranking (to make sure the gear did not break off), and it does. What else can I do to check the distributor? My other vehicles are direct ignition and diesel so I am not super familiar with trouble shooting them
Poke around on Google for pgmfi relay problems and see if that fits the symptoms you're having. Don't think its quite the same behavior that you're seeing..
![Happy](https://www.vadriven.com/forums/images/smilies/smile.gif)
