2.2L celica motor into a tercel?
Old 03-19-2003, 04:28 AM
POSescort's Avatar
POSescort is an unknown quantity at this point
You need to check the deminsions of the frames between the two cars. there may be moter mounts to be added or cutting and welding to be done. then look at wiring. its know already that the wires are probably gonna be diferent
POSescort is offline
Old 03-19-2003, 08:57 AM
Old guy
kutza's Avatar
kutza is an unknown quantity at this point
if you want let me know what yr your car is, and i can do a Jap-Starlet turbo engine swap out for you.
kutza
kutza is offline
Old 03-19-2003, 09:10 AM
mD5
back in ther vvti
mD5's Avatar
mD5 is an unknown quantity at this point
i'll sell you my 2.2L motor.
mD5 is offline
Old 03-19-2003, 01:07 PM
drifter's Avatar
drifter is an unknown quantity at this point
how about a 3sgte in a 1996 or 1997 corolla?
drifter is offline
Old 03-19-2003, 01:16 PM
Omerta
itsaqwik1's Avatar
itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1
kutza
PM with a good price .... to be honest .... i just didnt want to put that dinky ass stock motor back in it ... and its a 94 tercel. and can u tell me a little bit more on the starlet engine ur talkin about... thanks
David
itsaqwik1 is offline
Old 03-19-2003, 03:28 PM
LTDTEAM.COM
Rockybling's Avatar
Rockybling can only hope to improve
Default swap
How about NO scott? (Austin powers)
3sgte would be nice in a tercel, but its not really worth it.
Rockybling is offline
Old 03-20-2003, 11:08 AM
Old guy
kutza's Avatar
chk ur PM, call me and we get this monster on a roll ASAP.
turbo starlet engine is about 132hp stock, w/ IC setup.
www.kutza.com
kutza is offline
Old 03-21-2003, 07:30 AM
Omerta
itsaqwik1's Avatar
well.... i need a 2.2 for a 95 camry if you have it. Pm me please
Old 03-26-2003, 06:59 PM
.V
lLOlRlElN's Avatar
lLOlRlElN has disabled reputation
Originally posted by ToyotaTechGeek
the proper swap for that particular Tercel would be a 4EFTE which is a EPStarlet turbo engine. i think i remember it being 190 out of the box... as for those other swaps...it's not worth it.
the geek
a 4EFTE will bolt rite into yer tercel str8 up....the problem will be the wiring...dat will practically be da only problem.....you will want the tranny and ecu as well when u do this....swap out yer fuel pump wit a MKIII Supra 7MGTE Fuel Pump it should bolt rite in....upgrade yer turbo to a t3/t4 hybrid....get a larger intercooler and boost it to 20 PSI....i promise u the stock internals will hold....(for those that dont beleive me look into the paseo forums and tercel forums....and go to back-yard-productions.com....all of them have valid proof of a 4EFTE wit STOCK internals holding 20 PSI).....this will bring yer 4EFTE from 135Hp to about 300HP....i wouldnt lie to u i drive a paseo myself but im going a different route....this swap has been proven many times...it helps to go to the paseo and tercel forums man....
lLOlRlElN is offline
Old 03-27-2003, 04:31 AM
brake/steer/throttle
ToyotaTechGeek's Avatar
are you telling me to go to those forums? sheesh, i have known about this swap since early 90's through TRD direct. the trans is actually a hybrid of several different U.S. available parts. the problem is the flywheel.
ToyotaTechGeek is offline
Quick Reply: 2.2L celica motor into a tercel?
