2000 civic H.i.D. Install issue
I just bought an hid off ebay because I wrecked my car a while back and the lights got f'd up. What kind of kit would i need to have hids and still have my stock halogens?
I wired up the hid kit i already bought, which is a bi-xenon 6000k, but only the highbeams work, when I try to turn on my low beams nothing works, the high beams just stay on.
I need the kit to have stock halogens and hid low beams.... What should I be searching for?
Anyone have a clue also why the hid kit I have wired up now only works as high beams?
thanks
thanks
Still spinnin'
Re: 2000 civic H.i.D. Install issue
I mean HID's are pretty simple to install, did you check an make sure your wires goin into the connectors are right? Take a pic of what came with the kit an post, it'll make it easier.
Classified Moderator
He said he bought it off eBay so i was going with the assumption that it was one of the less expensive kits.
I would bet that it is plug and play into the stock plug right? i would also bet that the plugs with the hid kit are wired backwards.. there should only be 2 wires on the plug they sent you, switch them around and it should be fine
