2000 Civic Overheating
#21
Re: 2000 Civic Overheating
I just bought a new thermostat today in case it needs changing. Probably going to flush the system tomorrow.
I replaced the radiator cap. I'm not sure it's the right cap for this radiator; at first, coolant was definitely spraying out of it while driving. The cap was turned past being even with the radiator and I turned it back a bit, since then, no more coolant in that area.
I bought a new reservoir cap, but I notice that fluid is definitely seeping out between the cap and the hose that connects it to the radiator. Not a lot, but enough that I'm sure there must be air in the system. After getting back home, and shutting the car off, I noticed a steady but slow stream of bubbles rising to the top of the reservoir. I'm starting to think that it's a gas leak from the engine.
Considering disconnecting the heater and using block sealant to see if it helps, and I'll replace the thermostat while I'm at it just to be sure. Should I need to know for sure that I have a gasket leak before doing the sealant routine, or is it safe to just go ahead and try it?
#22
As for your "serious" question, yes, I have some automotive knowledge. Am I a mechanic? No. Is this the first car I've owned in six years? Yes.
Since I'm coming here seeking advice and not offering it, I'm wondering why you would even ask if I have "any" automotive knowledge. Not to mention the fact that the question is insulting, regardless of how seriously you're asking it.
#23
WEEEEEEEEEEE
Asking if you have any knowledge is not insulting, it help other to know just what YOU know, so if the advice given is going to go over your head, or not.
#24
#25
#26
#28
I would also inspect your radiator hoses while you have the system drained as dry rotted or bulging hoses can affect the flow of your cooling system. Just an extra precaution before you do something like changing a head gasket.
