2005 TSX Power Outlet Problem
Old 03-26-2011, 11:05 AM
BROSCIENCE
DwiZZy's Avatar
DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy
Default 2005 TSX Power Outlet Problem
Alright well I feel stupid for creating this thread but I really am confused at the moment.
The power outlet in the front of my car doesn't work. I went ahead and replaced the fuse and that didn't help. I also used a Voltage Meter to see if there was any power at all going to it and there wasn't. But the power outlet in the armrest works though?
DwiZZy is offline
Old 03-26-2011, 12:00 PM
WheelPowerRacin's Avatar
WheelPowerRacin has disabled reputation
Default Re: 2005 TSX Power Outlet Problem
http://www.tsxclub.com/forums/1st-ge...t-problem.html
This thread says that they are fed from the same fuse. If so, you have a wiring or fixture problem. The Honda EG models have a Thermo switch made into the fixture plug. If it gets too hot the solder melts to keep the car from catching fire. I assume the TSX may. Either way the next step is to remove the fixture from the dash and see if you have voltage on the wire connector.
WheelPowerRacin is offline
Old 03-26-2011, 12:30 PM
BROSCIENCE
DwiZZy's Avatar
Not what I was wanting to hear but thanks.
DwiZZy is offline
Cidone
Engine / Exhaust / Drivetrain
16
06-01-2010 08:25 PM
elmer20
06-27-2007 10:36 AM
95DCTEGGY
04-02-2007 08:41 AM
1995JettaIIIGLS
06-10-2004 06:24 AM
mpg9999
11-23-2002 03:44 PM
Quick Reply: 2005 TSX Power Outlet Problem
