350z transmission help
Re: 350z transmission help
those trans' are easy to remove and install should be on the ground in 30 minutes or so, remove the y pipe, drive shaft, shifter bracket and bottom shifter bolt, starter, trans mount, body tie bar, slave cylinder, then the bellhousing bolts including the bracket on the other side for the blank starter hole and the hidden bolt above the starter on the passenger side that goes in from the engine side.
this is one of the easiest transmissions to remove and install.
Thankyou very much. That will come in use.. Does anyone have any input on an xtd stage2 plus flywheel
