86 ford bronco II
Now rockin a Jeep
86 ford bronco II
Damn thing wont start replaced battery. no joy. Used starter fluid. works till fluid burns off. then no joy. think it mght be the fuel pump. yes it has gas. any suggestions
Go Team Marlboro
Re: 86 ford bronco II
welp...you know its a fuel delivery problem....so check to see you have fuel at the rail...then go from there..
The Pro to call.
check your fuel pressure.
also, check the inertia switch on the pass side floorboard. alot of times, it will trip from a kick of a passenger.
i got 5 on it
hmmm... I tried looking for the fuel shut off switch but no luck ill have to try again
Turn the key to run (not start, just one click to run) and listen for the fuel pump to kick on. It's fairly noticable wether it's powering up or not.
The Pro to call.
mother fuck....i thought on the Bronco II's it was in the same place as the rangers? (under pass side of dash, on floorboard, under carpet)
the exploders were in the back near the spare tire well....
eh fuck...ford likes to hide the fuckers everywhere. just look around, its in one of those three places.
i got 5 on it
