88 crx semi built ls
Old 07-15-2011, 08:58 AM
VaDriven Mayhem
Lord Humongous's Avatar
Default Re: 88 crx semi built ls
Originally Posted by Fabrik8
. That's probably just one problem you're having though.
This could be the understatement of 2011
Lord Humongous is offline
Old 07-15-2011, 11:13 AM
xeno's Avatar
xeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond reputexeno has a reputation beyond repute
o my just re-read homie said it already but ya.. saturated injectors (obd1) hooked up to a resistor box for peak and hold (obd0) not going to work... rywire makes plug and play injector clip converters.. are you using obd1 ecu? what about the distributor and alternator also?
xeno is offline
Old 07-25-2011, 12:11 PM
octavio18's Avatar
octavio18 has disabled reputation
A p75 ecu,obd1 distributor, and i did manage to put some obd0 injectors and it is running a little better i was thinking about using a obd1 pr4 ecu insted
octavio18 is offline
Old 07-25-2011, 12:33 PM
There isn't much difference between the P75 and PR4 calibration, so I don't think that will cure anything. If you're confident everything is working properly and you've done very much engine modification (I don't know what "semi-built" means), you probably just need a tune.
Old 07-26-2011, 08:34 AM
I <3 MY EG
JustaGSR18's Avatar
JustaGSR18 has disabled reputation
if you use the obd0 injectors than you need the resistor box, if using obd1 injectors then you need to remove and bypass the resistor box
JustaGSR18 is offline
octavio18
Honda
07-25-2011 12:14 PM
Quick Reply: 88 crx semi built ls
