91 integra problem
![pimpingreen13 is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
hey does you car turn over? Cause mine does but it dosent start. Let me know if that fixes your problem. thanks
Originally Posted by mportedcivicsi
-Yes they have them in stock, just called them $52 and change...Im picking mine up today.
Grip Syndicate
![mportedcivicsi has much to be proud of](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![mportedcivicsi has much to be proud of](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
where is the relay located? i cant seem to find it.
Yeah the car turns over like everything is good...just wont start. Basic trouble shooting yesterday leads me to believe that this is the problem...I will let you know if it works out!
Grip Syndicate
Well mine still wont start...anyone have any other suggestions? Everything seems good, but just wont start up. I get spark, hear the fuel pump come on and can smell the fuel if turned over to much, good batt, new main relay now...Help?!
Pong It Up Bitches
![1evilgs is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
another common problem with the 90-93 teg is the ignition switch I had to replace one in my old teg
i didnt have a problem with the fuel pump but i really dont want to drop the tank especially since its full. Yeah i thought about the ignition switch but i think if it was the switch it would still start every once in a while. thanks anyways
Originally Posted by drft240
Or replace the car. Lol If you have had a problem with the fuel pump test that first before you buy parts you dont need.
well i changed the relay and it still did not start.
no didnt really have time......been busy as hell.. i cant hear the fuel pump come on when you turn the key over.. Ill have to check for spark later...batterys also dead.
Originally Posted by ZeroMR
Did you check to see if you are getting spark and fuel?
