92-95 4dr to 2dr front end conversion
I've got a 95 4dr civic. I like the look of the front bumper and corners from the coupe/hatch. I just want to confirm what I will need to change it over to look like the 2dr.
Does anyone know if the cpe/hatch fenders bolt right on? Just wanted to make sure before I buy the fenders.
And I'm assuming the hood is the same for ALL 92-95 civics. Please correct me if I'm wrong.
Any info is appreciated. Thanks.
Die reinste Bösen.
Re: 92-95 4dr to 2dr front end conversion
the you have an eg9....the eg6 (hatch) ,eg9(sedan), and ej1(coupe) all have same front...its the rear that distinguishes these apart. The front fenders, front bumper, and front hood should all bolt on bro.
92-95 Civic coupe fenders will not fit properly on a Civic sedan.
The 92-95 Civic coupe/sedan use the same rear bumper.
To make your sedan look like a coupe from the front, you have two options:
1. Use the coupe front bumper and modify it to fit. It still will not line up perfect on the sides though.
2. Cut the front portion of the coupe fenders and weld them to the rear portions of the sedan fenders.
The 92-95 Civic coupe/sedan use the same taillights.
The 92-95 Civic coupe/hatch use the same hood.
Did you try it? Or know someone that tried it? I did have the coupe bumper on for a while, but you're right, it does need modification to get on there right. Maybe I'll just modify the front bumper, I guess I could live with the corners, I'll show it to Jeff @ Dreamworks to see what he can do.
Thanks everyone.
