92 Volkswagen Jetta Problems.. needs help
Re: 92 Volkswagen Jetta Problems.. needs help
Oil was leaking from the back of the speedometer cable onto the instrument cluster/panel. No i am not car savvy i am scientist not a car mechanic. All I want is a little help with my vehicle. The wires are smoldering because of the 90 weight, I thought that i had already addressed that. Which would cause a smoke, which is a little dramatic on my part. it was more of a haze, kinda like smoking a cigarette but a worse smell. my windows are also down so the smoke was ventilated (its VA and 70 degrees)
The whole drive train has been replaced clutch plates* clutch* shift linkage* etc. (less than a year ago) the car has not been driven until the last 3 months and when i press the clutch shift into 2nd, give the car gas the RPM's will drop from 25 to 10 this is with my foot all the way on the floor but the gas pedal is a little stiff anyway. The gas pedal being stiff shouldn't have that much adverse affect on the power. Their is a power drain coming from the car somewhere and i was thinking maybe my throttle body.
i am using 9o weight because it is a manual transmission. Clearly you can not use the same gear oil in an automatic vs. manual completely different tranny
there is no way for it to leak oil in your cluster i think you were having an acid trip
my advice is you drive it down 264 and smash it into a wall
gets the dumb hippie off the road and it'll get a shit box mk2 you ruined in pick n pull where it belongs.
Forcibly Repped
It's quite impossible for fluid to get through both those and then work its way up the cable and into the cluster
well in my tranny that i have in my car the oil did leak onto the instrument cluster.. that is besides the fact.. i just need help finding out possible things to check for a power drain problem. I know it is more of a drive and than diagnose type of deal but i was hoping that i could get a couple more hints than what i already think. Such as it is missing, i checked my spark plugs and they have no crud or gunk on them. So i need to see maybe if it is missing which i guess i have to test the spark on the spark plugs. My throttle body, distributor and its cap, would the gas have an effect on it?? It uses unleaded but should i start using an octane boost??? I am trying to receive help on this because i fix my own cars, therefore i can learn more. It is clear i don't use the best grammar and punctuation and yes maybe my sentences aren't completely coherent but is their advice that you can give that isn't about me doing negative things to stuff i own or myself?
The best advice you'll get is to take it to somebody who at least knows what the hell they are doing working on a car. You are incredibly clueless as to what's going on. Honestly you're doing more harm trying to fix it yourself.
