93 eg k swaped 6 spd non lsd tranny problem
Trans always shifted fine. No grinds, slips, chatter, etc. One day I got in the car and could not go into any gear. Next day worked fine again. Drove fine for couple hundred miles then went to shift on the highway and would not let me in any gear. Replaced bled fluid and replaced master and slave. Still will not go into any gear. Any suggestions of what it might be? I thought throw out bearing but the tranny is not making any noise. If I put the car in gear and then start it the car pulls like it is an automatic and I can not get it out of gear unless I turn the car off.
broken clutch spring, or bolt backed out of flywheel most likely broken clutch though
if you kept pushing it in theres a good change you have bent your clutch fork as well
heres a visual aid for what your looking for
![](http://i9.photobucket.com/albums/a96/destructivehate/2011-07-20153717.jpg)
just pulled this out of my car a week ago
sounds like your clutch has gone to shit, sometimes the springs in your clutch disc will fall out or become very lose. Then becoming stuck between the pressure plate and disc rendering your throwout bearing and slave cylinder useless.. and you stuck in or out of gear..
^ he beat me
^ he beat me
There isn't any need to make two threads about the same thing. I just deleted the other one. Don't make a third.
