94 civic hb. Oil Light. Need Help Please
Re: 94 civic hb. Oil Light. Need Help Please
Ive added a picture. im wondering where the oil sending unit is located and what is that black square thing near the oil filter? someone posted say its the same fitting as what some turbo guys use for something, sorry i do not know about turbo and how the setup goes.
oil is drain and filter has been removed.
Anti "DONK"
My old 93 was doing the same thing, exactly like you were describing, I though it was the sensor or pump...2 days later I dropped the oil pan to replace it (previous owner had an oil pan from his old boosted z6 on it) and found this, Instead of going any more on the Z6 I went ahead and ls swapped it...
Metal pieces, some almost 1/2 inch long
Anti "DONK"
Sorry that pic wasnt very clear. I lost my old pictures... There was specks and slivers of metal in my oil pan, motor still ran fine and sounded normal but something ate itself up and the shavings were blocking my oil pickup...I never went into the motor to find what actually went wrong, just decided it was time to go b series
TurboPipingSystems
Check the wire as Fabrik8 says. If you have to, do a continuity test on the wire from the sensor to the ECU. If that happens to be fine, then borrow an ECU from someone. If it does the same thing, then your oil pump is probably done for.....
