94 coupe won't start... turn key to on postion just gives constant priming fuel pump
![tech2149](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![tech2149](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
if you have a no cranking problem, another ecu is not going to do anything for you. you can have no ecu at all and the car will still crank. you should start with getting the motor to crank over before you check for anything else. first off put the car in the key on position and jump the starter to see if it cranks. if it does crank over give me a call and I will tell you what to do next. or if you don't know how to jump the starter call me and I will walk you thought it. 757-286-7710 Eric.
![Dillweed](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Dillweed](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
![Facepalm](https://www.vadriven.com/forums/images/smilies/facepalm.gif)
![dustyb20](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![dustyb20](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
was the starter solenoid and wire... guess my harness short may have went further then i thought... both replaced and everything in excellent working order now, thanks for all advice and help
93civiccpe
01-28-2005 03:26 AM
