96 Accord. engine randomly cuts off
Old 10-15-2009, 04:53 PM
JJ
xxpnoyballa543's Avatar
xxpnoyballa543 can only hope to improve
Default 96 Accord. engine randomly cuts off
Couple weeks ago my car engine randomly died on me. I pulled over and it started up fine. It started happening more and more frequently, and it becomes harder to start each time. After it finally cutting off on me in the HRBT I decided to get it looked at. I have a new ignition switch, and a main relay I pulled from the junk yard, and the problem is still happening. I have new sparkplugs and wires. My mechanic says I need to get a new main relay. It just seems unlikely that I would have two bad relays, and Im in a tight money situation right now. Any suggestions before I go off and by a part I dont need? I have the F22B2 engine, non vtec
xxpnoyballa543 is offline
Old 10-15-2009, 05:15 PM
Speak&Spell Anyone?
Cpt. Non-Spell's Avatar
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
Default Re: 96 Accord. engine randomly cuts off
its your electrical portion of your ignition
Cpt. Non-Spell is offline
Old 10-15-2009, 06:11 PM
JJ
I put in a brand new ignition switch, just the electrical, and im still having the same problem
Old 10-15-2009, 09:01 PM
SmokeCRX's Avatar
SmokeCRX has disabled reputation
Bad igniter. I would bet money on it. Can replace distributor cuz its inside it or... Call Honda dealer to get just the igniter. Also if you pull the igniter out of the distributor and its black in color...it IS the problem. And if goin to use junkyard parts...do not replace it with a black one (look for a brown one). I've Been workin on Hondas a while...if it is what you say...this will fix it. Good luck buddy.
SmokeCRX is offline
Old 10-16-2009, 05:22 PM
JJ
Thanks a lot for that input...I will def. try this asap and let ya know how it turns out
Old 10-17-2009, 11:04 AM
Speak&Spell Anyone?
I'll charge you 80 bucks and look at it at work...
Old 10-17-2009, 01:40 PM
JJ
I think honda doesnt even charge that much lol. im tired of buyin parts that aint makin a difference, so im about to take it to the shop monday. the screw to take out the distributor rotor was also completely stripped
Old 10-17-2009, 03:30 PM
baller/dickbutt#69
nftuatn's Avatar
im sure honda has a diagnostic fee of at least 80 bucks...may be like 100.
its to stop people from getting told what wrong and just fix it thereself...
there is no shop that diagnoses for free..
nftuatn is offline
Old 10-17-2009, 04:10 PM
JJ
I will be getting in contact with Cpt no spell monday, broke right now
Old 10-17-2009, 06:54 PM
has a huge dong
VB2NER's Avatar
are you throwing a cel? does it die at idle, or when it is driving,or both? 5 speed or auto?
i love how people swear up and down they know exactly whats wrong, but have no info to go on...
VB2NER is offline
Quick Reply: 96 Accord. engine randomly cuts off
