96 civic gsr swap help
Re: 96 civic gsr swap help
ok well i just found out its not the crankshaft position sensor its the knock sensor and the o2 so now im back to square one and i need to find out if that is important for the vtec to work
Fix the fucking Cel... Then work towards other things that might be causing the issue. The ECU is telling you that you have a bad 02 and the knock sensor is not reading. go to http://www.ff-squad.com/technet/
hello ppl i have a 96 civic and i just swapped a 96 gsr in it i used the stock d series harness because it had the vtec plug on it and everything and the car does not crack vtec at all it runs perfectly beside a high idle i have a cel on but it for o2 sensor and ckp sensor but from what i have been told that stuff dont matter so if anybody can help me out that would be awsome.
i pooped a squirrel
Oh for fucks sake, unless you bypass the knock sensor via the ems vtec will not engage, this is common knowledge. You need the crank position sensor hooked up as well being its a crucial sensor. How about you quit being a lazy half assed fuck and clear all the cel's and hook up all the sensors? Then maybe, just maybe, your slow ass pile of shit will run right.
why is it every time i try to ask a simple fucking question there always has to be some fucktard that has to talk shit this is the reason nobody gets on here anymore they think they know everything and they really don't i am done with this website fuck all of you
You wont be missed.
