97 Car wont start
Old 12-13-2009, 06:52 AM
94civicdxt's Avatar
94civicdxt has disabled reputation
Default Re: 97 Car wont start
try and test your MFI relay.
94civicdxt is offline
Old 12-13-2009, 02:54 PM
xboxhaxorz's Avatar
xboxhaxorz has disabled reputation
Originally Posted by JB@RameyBuilt
Was this before or after you backed out the driveway and the car cut off and wouldn't start? So it has started since you posted the thread?
-Justin
This was the next dy after i had backed out. Somebody suggested i try the spark plug screwdriver thing to get a spark which i did. They told me to press the gas while starting or use starter fluid. I did the gas and it started and stayed on, i didnt drive it though i just turned it off.
Basically 12/10/09 i backed out the driveway and thats when it stopped starting
12/12/09 i started it by pressing the gas
I am not sure where this MFI relay is and how to test it
xboxhaxorz is offline
Old 12-13-2009, 03:21 PM
Between Bikes
pasty's Avatar
pasty pasty pasty pasty pasty pasty pasty pasty pasty pasty pasty
Originally Posted by xboxhaxorz
I had an issue about a wk or 2 ago when my car wouldnt start it tried but didnt after a while it did and i drove home. Few dys later it happened again so i drove to advance put new spark plugs in and it started right away, next dy it started i was backing out of drive way it turned off and wouldnt start. I just got done changing the wires cap and rotor and i still have the same issue.
Its a 97 del sol si, i just had a full timing belt job done and an oil change not too long ago. I thought it was gas so i put a full tank in and still nothing.
Did you check the wire to the ignition coil? I had one that was corroded and sometimes it would start, sometimes it wouldn't. I tried a lot of things under the hood, and moving around would move the wire around, which would allow it to start. Needless to say, I had a lot of weird ass ways to start my car, but they were all not really helping.
pasty is offline
Old 12-15-2009, 01:14 PM
xboxhaxorz's Avatar
Well most of the things you guys listed were covered under warranty so i decided to have it towed to honda. They looked at it and said it started fine nothing was wrong i was wtf so i checked it myself and they were right i started it fine 2 times.
I left it overnight because i thought it might not start when they tried again and it didnt they called me and said it was the auto air control valve or something. Cost $636 because its not under warranty. Does that make sense its the air valve and why did magically start without me pressing the gas?
Old 12-15-2009, 06:35 PM
If it's an idle air control valve problem, it's an intermittent problem. The IACV bypasses air around the throttle plate, which is what allows air to enter the engine during starting and idling. If it was bad, there wouldn't be any air going into the engine, which is probably why it starts when you press the gas.
Did you already pay for this? $636 is a massive amount of money for a part that you can easily change yourself and get much cheaper either used or new.
Old 12-15-2009, 06:51 PM
Between Bikes
pasty's Avatar
Simple problem, better than mine at least. My problem is that my car starts intermittently and all I've been able to do is trace it to the flywheel/starter area. I think it's getting jammed or something.
Glad you got it resolved.
pasty is offline
Old 12-15-2009, 06:53 PM
Function > Form
6CYLINDRSYMPHNY's Avatar
try one of the 96 others...
ehh???
EHHHHHHHHHHHHHHHHHHHHHH????!?!?!?!?
6CYLINDRSYMPHNY is offline
Old 12-15-2009, 06:57 PM
ohh yea
integrab17's Avatar
integrab17 has disabled reputation
sounds like ur problem is ur main relay under the dash. (driver side) hopefully
integrab17 is offline
Old 12-15-2009, 07:02 PM
Doesn't make sense. Everything is getting power, else the car wouldn't start when pressing on the gas pedal.
Old 12-15-2009, 08:33 PM
xboxhaxorz's Avatar
No i never pay right away i always check on forums and shop around. Although i do need to have it fixed soon since its my only car. The intermittent explains why it started that time and not before. It seems to go for about $200. I dont think i can change it myself though, a tune up is about all i can do.
Quick Reply: 97 Car wont start
