99 CIVIC SI. Taching out way before redline!
Re: 99 CIVIC SI. Taching out way before redline!
no big deal, just trying to help. You should def be able to see a plug under the distributor or in that area that is not plugged in. its just going to be a one wire plug(of course).
Well i have a 99 SI. Here is the story, i have posted numerous threads about it but nothing on it yet. Full story!
Bought the car, test drove it and this thing CRACKED into vtec! Drove it around for about 20 minutes before making the deal. Drove fine! On the way home on 95 i was gettin on it and it hit around 6500 and it the rpms were taching out it sounded like. Of course, this car redlines at 8 so it had more to go. Stopped at the gas station, put a hose back on which i thought was the problem. It didn't do it then, 10 minutes back into driving it, it did it again! Now ever since then it would do it on and off. If i havent went into vtec for awhile, when i would do it it would do it fine.
It does it alot on the highway, if i drop it and down and hit the gas and go it will go into vtec and it will tach out most of the time on the highway if i do that.
Now, im pretty sure i have no vacuum leaks. I recently was reading up that my car only takes 4.2 quarts of oil, i usually put 5 1/2 in. ( thats when it reads full on the dipstick ). I know vtec is powered by oil pressure ( atleast thats what i heard ). If i have to much oil in the car, that could defintely effect it, correct?
On the vtec solenoid i have a wire comming down from under the solenoid cover. Just hanging down, thats it. I was told by some people on here you don't need it, its fine. But reading in a book, that piece is called a VTEC SOLENOID CONNECTOR. To me, that means that it isn't even kicking in if that isnt working.
Let me know if you had this problem with your SI, or anything with vtec!
Also, as my name says i used to be a 5.0 guy, so im slowly learning about Hondas, i wanted to get the best of both worlds!
Seriously, WTF is wrong with you that you're racing on the street like that (and your dad is apparently just as devoid of common sense) and then posting about it on a public forum? Is he trying to bond with you by buying a stock 240 and street racing with you? Are there any intelligent people in your family?
Normally I'd help you more. I'm not feeling it right now though. Anyway, If the solenoid isn't connected, there is no way VTEC is engaging. If you're reading full on the dipstick, you should have no problems with oil pressure assuming nothing major is wrong with the engine though. But that doesn't matter at all if the vtec solenoid is not connected to anything.
And by the way, thanks for spelling 'solenoid' correctly. For some reason 90% of Honda owners can't do that. Don't know why. You're already ahead of the game.
Fixed. I took all the deuchebag street racing references out. And what the fuck is taching out? Did the Mustang club kick you out because you used words like that?
man i bet you feel like a tough guy now, lets downgrade somebody through the internet. but in person, id knock your fuckin teeth out, end of story.
If this was a nice, normal thread without the street racing references (that don't serve ANY purpose in solving your problem) then my attitude would change, and I'd help you like everyone else. It's very simple really.
