accord suspension problem
i have an mr2 now
can anyone help me with my accord, the left side of my car is lower than my right, if you had this problem before let me know how to fix it or if you know a way to fix it please write thank you
stock suspension? coilovers? springs? adjustable struts? stock struts?
stock suspension: replace it, fuck it!
coil overs: make sure both sides are adjusted properly, or maybe you need new struts
springs: got new struts?
adjustable struts: adjusted properly?
stock struts: get rid of them fuckers!
just my .02
steve-o
just my .02
steve-o
Accords are famous for one side being lower than the other. There isnt a thing you do about if you have springs. If you have coilovers just raise the left side up a bit....
I had the same problem with my right front though. I just adjusted the difference.
when the springs were installed, was the weight of the car put on the springs and ride height correct before the front lower strut bolt was tightened? If not there maybe a preload on the bushing causing it to not fully colapse to the ride height.
This can happen over time, if the car is used to having only the driver in the car and no passenger (hence the reason why the LEFT side is lower). Replacing the shocks/struts should help; start with the front.
Originally posted by Nates95Accord
Sure didnt help on my car....and i have koni yellows
Hmmmm, Accords must be POS.
J/P
