Any advice for a 4g63 head reinstall
#31
Too each his own
Re: Any advice for a 4g63 head reinstall
ya the starter was hot as hell and then it stareted clicking, not sure if i burned it out or not willl keep trying tomorrow
#32
Too each his own
just got the car started finally, however it took it along time before i could let off the gas for it to idle on its own, and it was idling kinda high (1300) i did mess with the throttle cable a little bit though probly the deal. anyway gonna let it cool down retorque the head bolts, and check it out
#33
Too each his own
#35
Too each his own
alright got the car all together put oil and water in it and went for a drive today but it had no power at all like it was running to lean or something the timing is spot on however the cam postion sensor i didnt time i just put it where i thought it was before, so im sure thats the problem and i also ran some sea foam thru the oil and gas to clean out everything but still no power at all but got rid of the backfiring and stuff
#37
Too each his own
no it sounds fine now and sounds like every thing is in order just no power and the a/f gauge reads lean as hell
#38
Too each his own
got about 120 on 1 3 and 4 and 60 when the car is running in the number 2
im going to see if the rings are bad this weekend if not im going to the guy i bought the head from and getting another one if not im just going to buy another jdm 4g63t 6 bolt
#40
Too each his own
okay getting the head back from the shop tomorrow and going to re(re)install it on the car and with no luck it will be running again
