B-SERIES MOTOR QUESTION:
corona connessuer
Re: B-SERIES MOTOR QUESTION:
ok you could have a fuel pump thats dying or the fuel filter is getting clogged. in the first 2 gears it can keep up with the demand that the engine is placing on it. in the higher gears the engine puts a greater strain on the fuel system causing it to feel like it is lagging due to the reduced fuel flow. are you running any sort of power adder??? nitrous? zex? did you upgrade your fuel pump? there are more factors that need to be adressed before a correct assumption can be made. in no way am i saying that this is your problem, im simply stating that it could be an area that you may want to take a look at. i had this problem with my nitrous system in the higher gears when i was running my stock fuel pump. now i have a bigger pump and now no more problems!
DESTROYS DONUTS !!
everyone except FR3SHTOD3F is wrong, just about every ls motor feels good as hell in first and 2nd and then seems alot slower in 3rd, hey lsvtec2go,you want to change that, put a power adder on that bitch.......
corona connessuer
