b series questions
Turbo VTEC-E
Re: b series questions
Had the exact same problem on my turbo dseries. Bad dizzy. I was even still getting spark from it but it was just too weak. Not to say that that is for sure the problem here but it is an option.
check the ignition coil fuse inside the car, also check the batery. if still does not start check to see if you got power to the ignition coil if you do and still have no spark you might have a bad ignition coil. this things go out with out warning.
