b16 questions
Slowest HRC Member
![BAD4DR has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![BAD4DR has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
i.e. 100 hp/liter = him with 20 more HP. More torque, and better bore/stroke combo for the top end than an LS = you
![Embarrassment](https://www.vadriven.com/forums/images/smilies/redface.gif)
Slappin Curtis
![bluesrt2004](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![bluesrt2004](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Thank You
Slowest HRC Member
K motor is 15-20 year old newer technology and design.
Not to say a B-series isn't good, but fact is, it's all about head flow. Want a good example, the flow on a competition ported B series is about equal on the top side to a stock SRT-4 head. The SRT-4 head will out-flow it tremendously on the low end.....
I haven't seen specs for a K series, but if they've fixed the ports, properly sized the valves, and taken care of some things, it's going to be better. From there, choosing the proper bore/stroke for the RPM range, and other factors come into play. I haven't researched a K at all, but I understand it's far better.
Want factory fast? Quit looking at Honda's! Z06 Vette comes to mind!
got some fake hp
![wisepanda has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![wisepanda has a reputation beyond repute](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
and if you want to get technical the bore to stroke ratio on both ls/b20 vtecs suck, especially since they are not mint to rev! resulting in a motor that will only last 60 to 70 thousand miles before needing to be rebuilt.
so thank who ever you want but your comment was irrelevant
why cant people ever just answer the origional question at hand and stop trying to sound so smart
![Wink](https://www.vadriven.com/forums/images/smilies/wink.gif)
Slowest HRC Member
Nope, no comparison implied.....
obviously not =
3 mm more bore = better bore stroke combination.
Both are designed to produce excellent low-end power. Which is kind of interesting, given that the rod length is so short compared with the stroke....
But...then again, it's a street engine, designed for economy, not a race motor....
obviously not =
Slowest HRC Member
As for the original question:
Nothing. There are no "easily interchangeable" parts on the LS that will give any serious performance advantage. You could have the head machined, and use the LS bottom end to good effect, but, that's not under the category of "easily" anything....
got some fake hp
obviously not =
obviously not =
i was stating the idea behind putting the two motors together. THEY are exactly the same. Meaning SIMPLY how the motors are put together(oil lines, warter pump choice, etc) ASSEMBLY was all i was talking about.
im not arguing with anyone, i didnt know someone on VADRIVEN was goin to break it down and be suck an ass about it.
![Roll Eyes (Sarcastic)](https://www.vadriven.com/forums/images/smilies/rolleyes.gif)
Slowest HRC Member
i will leave this thread to HONDA RULES! he will answer any question you have!
