B20b swap issues?
#21
Re: B20b swap issues?
Agreed. Now is it related to insufficient flow or the injectors opening/closing too long, too little, too early, too late.
I wont go into timing yet.
If it's a bad fuel pump, why would it run "OK" under hard throttle when the demand for fuel is greater?
why?, d-series, b- series, all use THE SAME SIZE 240CC injectors.
you have a point there, it is a 200K mile chassis
#22
I really appreciate all the feedback. So from what ive gathered so far.... its either the ECU map or a fuel issue? Fuel issue I can I can figure out. But the ECU completely throws me. I have no idea about any of that. I have no idea where to start, what I would even need or be looking for
#23
#24
entirely possible. I bought a bunch of ECU's about 6 months back to chip and guy insisted he bought it chipped and wanted $100 for it so I popped the cover open and showed him this picture. His face was :0
I gave him $30
Look at IC4 and IC4. There are dioede and resistors added elsewhere in the board but this is the quickest way to be sure
CHIPPED ECU
UNCHIPPED ECU
This is a great site: http://www.superhonda.com/tech/honda...ogramming.html
I gave him $30
CHIPPED ECU
UNCHIPPED ECU
#27
It's a non VTEC LS ECU. It will at least eliminate his part throttle hesitation problem right? And will eliminate 2 variables = incorrect map burned into a "chipped ECU"
If the problem persists, start looking elsewhere.
#28
Will check and see if it chipped when I get off work. According to the gut he said the OBD1 was hardwired in to eliminate the jumper and potential melting issues or something like that...?
#30
Is be skeptical to even run a stock vtec ecu just cause of the fact that its a b20. Even with a base map id feel uncomfortable. Everyone knows how sensitive e those motors are even with a mild build. Personally if u have funds is just drop a single in until you were more familiar with the b20 set up. Your going to have problems. Not bashing you op just trying to give good advice bro.
